Card features in review module
Card composition
The card under the review module is composed of two sides: the front is the question and the back is the answer (note content)
Modifying the back card content will directly affect the corresponding card content in the learning module
How to add handwritten annotations
Review Module → Select Deck
→ Click on the card to be labeled on the left
→ Select “Card” in the “Card”, “Mind Map”, and “Document” columns above
→ Click “Edit” on the right
→ Select the “ξ handwriting” icon in the pop-up menu bar
→ Write by hand, add on the front or back of the card
How to add a recording
Review Module
→ Select Deck
→ Click the card on the left to add a picture
→ Select the “
Add Voice” icon in the pop-up menu bar→ Add recording files to the back of the card
Use the function of" Extract Questions from Notes "to add the front of the
The entire process gif
How to add pictures
Review Module
→ Select Deck
→ Select the “
Add Photos” icon in the pop-up menu bar
→ Add photos in the photo library
→ Select "No" to add the picture to the back of the card
If you select "Yes", you will enter the "**Extract Questions from Note Content**" function, then select the picture to add to the front of the card (if you use the "**Extract Questions from Note Content**" function, you can add the picture to the front of the card again
- Drag pictures from external app to card
→ Drag into the list on the left
→ Add pictures to the front of the card
→ Drag the copy card edit box on the right
→ add the picture to the back of the card (using the "Extract Questions from Notes" function, you can add the picture to the front of the card again)
How to add tags
Review Module
→ Select Deck
→ Select the “
label” icon in the pop-up menu bar→ Add a label to the back of the card
Use the “Extract Questions from Notes” feature to add to the front of the card
How to edit and sort comments
→ Click the card on the left to edit the sorted comments
→ Open the card question edit box and click “Edit” on the right
→ Select the “Edit Comment” icon in the pop-up menu bar
→ Edit and sort comments on the back of the card
How to extract questions from note content
You can also add all the comments to the front of the card (questions) to form a unique review card
→ Click the card on the left to extract questions from the note content
→ Open card question edit box
→ Click the “Extract Questions from Notes” option on the right
→ Select the back of the card (note content) to add the front comment content
→ Extract questions from notes
