Direct 📝 writings on mind map: should stay on Nodes as an option
I love direct writing on mind map and nodes on mind map
Thank you for this speciality again and again :innocent::innocent::innocent:
But there is a thing makes the problem
Direct writing on captures can’t stay on nodes itself, it goes background.
If user want to write on nodes, he/she needs to :
  1. two click on nodes or :hammer_and_pick:
  2. opening the doc screen.:telescope:
(1) is the problem because
  • willpower issue, two click is useless and not explainable as a fluency
    • If now he/she want to write another node, he needs to click everytime another node. That’s a another willpower issue
  • Lots of bugs happen in opening and closing window process (we talked about before)
(2) is the problem because
  • there are lots of user want to use just mind map screen (there should be a option to them)
  • There is no point/meaning left in mind map writing if he needs to open doc screen
Support team may say as an answer
-Then use direct writing on background and don’t open window or doc screen
Answer to that answer
-If user built frames or mind maps from captures, everytime he added something he needs to REARRANGE the background annotations from 0
because everytime he added another node or delete one node:
The framework or mind map takes completely DIFFERENT position.
That’s why the user wants also direct write on nodes (wish) like on background (now).
-Another reason: there is no review function for background annotations
SO
WISH:
DIRECT WRITING ON NODES(captures) LIKE ON BACKGROUNDS without opening window or doc screen.
Hello. 3.7.5 version supports binding handwriting to cards, you can try it, but at present it still does not support direct association to the card editor
MarginNote-Relight
But handwritings are still not embedded on the cards. I can’t move cards with handwritten notes on them.
Hello. You need to bind first before you can
MarginNote-Relight
Hi,How to bind it?
[375 focus mode handwriting binding|video]
Handwriting binding can only be done if there is at least small part is extended into mind map.
This doesn’t give us ability to write and embed handwritings only on cards.
Yes, but you can double-click the card in handwriting mode and enter the focus mode of the card first to write by hand.
Oh.thank you. :smiley:
It is inseparable from the joint efforts of everyone :smiley: :smiley:~
MarginNote-Relight
What is the plugin that you have used to draw freely on MindMap?
