Exporting a Mind Map
Export Mind Map to PDF format
Study module → Open the Note→ Click the export icon in the upper left corner →Select “All notes” on the pop-up → Select “Export in PDF Format“
→ Only select “Export mindmap” → Click "Export“
→ Wait for a few seconds according to the number of pages of the document until the PDF interface pops up
→ Click “export” in the upper right corner → Share to other apps
Export Mind Map to other formats
Study module → Open the Note→ Click the export icon in the upper left corner →Select “All notes” on the pop-up→ Select the export method under “Export for open in other applications”→Follow the instructions for the next step
Derive partial Mind Map under focus branch
If all the exported Mind Map are too large, or only part of them want to be exported, you can use export Mind Map under focus branch, which is available in focus modeStudy module → Open the Note→ Enter focus mode
→ Click the export icon in the upper left corner → Select “focus branch” in the pop-up interface→ Select “Export in PDF Format” or Select the export method under “Export for open in other applications” → Follow the instructions for the next step
