I want to make handwritte ON MINDMAP (like we do on document)
Think about it with all beautiful tree notes with your own handwrite, drawings and pictures, wouldn’t it will be beautiful ?
The issue is that the mind map isn’t static, like a PDF. Positioning of mind map notes etc change when you add, delete information, and you can’t move, link, or scale hand writing as a result. That’s also why hand writing is not available on ePUB (you can change font sizing, line spacing, etc)
Yes, the markup is confusing and redundant unless the movement of the brain map is permanently turned off, or the markup is limited to a single brain map card range. This feature we have in mind and may be launched in another form.
@isaatalay42 I don’t know your motivation for wanting to draw in the mind map, but I imagine it is not for drawing itself, but because you want to make more free form connections between notes or group them. Like arrows, circles and other visual ways to mark the relationship between notes?
If so you are not alone and it can be implemented without the difficulties with drawing that @Relight_Support-Team mentions. There is already multiple threads with users, including me, who complain about the lack of flexibility in the mind map and want to use it more like a concept map.
@isaatalay42, consider letting the developers know you also want this. Cheers! ![]()
Thank you for your suggestion. I have already raised your request to our Development team. As mentioned earlier, all user requests will be considered and implemented but we cannot assure a time frame when it will be put into effect. Please feel free to contact us again if you need any assistance and we will be happy to provide further help.
