Scroll wheel of mouse for Zooming?
Continuing the discussion from Zoom :telescope: sensitivity:
Is there any way for I can use scroll wheel of mouse for zooming in mind map ? (not up or down) (at iPad)
Can Mac users use scroll wheel for zooming in mind map?
Hi, on Mac you can zoom by holding down the command key and using the up and down scroll wheel. I tested it with iPad os14 and it doesn’t seem to be supported.
So we need to wait iOS 15 :upside_down_face: ?
It’s hard to say, and I can’t figure out why the same operation isn’t supported on the touchpad of the Myriad keyboard.
Just joking, I like Pencil for MarginNote. handwriting updates more important for me. thank you for replying back :blush::nerd_face:
I have the same problem. I use my magic mouse 2. With the mindmao tool ithoughts, this function is excellently solved. Just have a look. Navigating with the mouse, zooming in and out with the scroll function is great. Shouldn’t be difficult to implement. I also like to press a function key to be able to use this function.
