Any changes to MN folders & categories?
Thanks, @ringmaster555 … I’ve been sympathetic to the MN3 development team addressing the many, necessary fixes to make the app work adequately, but the existing system of folders & categories makes difficult to work in MN3.
Anyway, like you I’ve also got DEVONthink, and likewise use it to store my files for annotation. But I hadn’t thought about use an Index folder for MN3 files. Would you mind walking me through your set up? Sounds like it might provide some kind of stop gap approach (albeit with the limitations you’ve pointed out). Thanks so much!
@jprint In order to open files in my DEVONthink index and prevent the MarginNote database from reimporting a copy of the same file (another limitation of MarginNote in general: There’s no checking for duplicates when opening outside of MarginNote.), I use a Keyboard Maestro automation script to write lock directories while MarginNote is open and unlock them while MarginNote is closed (During this time, you can import new files in DEVONthink.). The script I have is outlined here: Allow Opening From ~/Library/Containers/QReader.MarginStudyMac/Data/Documents/ Without Reimport
This way, I can open files in DEVONthink directly from the ~/Library/Containers/QReader.MarginStudyMac/Data/Documents/ directory with expected behavior. This system works pretty well. It’s not ideal, but it’s a decent hack until the development team implements better database structures, import logic, and file browser user interfaces.
Thank you so much for this, and I’m sorry for my belated reply. I’ll take a closer look at this to see if I can figure out the set up and Keyboard Maestro script.
One of my concerns is figuring out if / how this might work with the DEVONthink clipping that I rely on. Does you approach allow you to still use the DEVONthink clipping features?
Ok, I’ve read this a few time and I think I can imagine how this is supposed to work.
While I’ve done a few things via Keyboard Maestro, I don’t have a strong command of it – so I’m not clear on what to import and how to apply it as a script to make this hack work. Could you walk me through that a bit – if you’ve got some spare time to do so?
Many thanks, again…
Any new developments with this ? Has @Support-Team worked on this at all???
Many of us desperately hoping something has happened on this front…
I’m now using Margin note 4. I still cannot get categories and folders to operate sensibly when in study mode: the categories given to documents in document mode are not visible when in study mode. This leaves a long list of disorganised documents in study-mode, rather than documents organised by folder or category. When I got to table of contents of a particular document in study mode, the category is shown, but I cannot find how to show the category of all documents in a list, so they’re organised.
Surely this is now possible? If not, what’s the point of organising documents by category if this categorisation is unusable once in study mode?
Thanks.
anyone?!
Your steps are, while viewing a document:
  1. enable document tabs
  2. Add a new tab
Now you can view documents by category or by folder.
Thanks for your reply.
But can I see the categories of documents once they’re in the StudySet: I have 50 documents in the StudySet, but they’re simply a long list of documents with no way to have them in folders once in the StudySet, making document management very difficult.
Thanks again.
Any update on this? When in Studyset, there is no way of ordering documents in alphabetical order - they are in a random order. They can be manually reordered, but this wastes a lot of time. This is such a simple issue - has it not yet been addressed since I raised it 17 months ago? This app is so powerful but is let down by some simple issues.
