Emphasize mode
Emphasize mode
Only notes that have been excerpted can be emphasized
Ⅰ.Emphasize in excerpt state
:warning:Only PDF can be emphasized in the excerpt state
Select the notes that have been excerpted from the document interface → use the hand-shape excerpt tool to select (rather than excerpt) the content to be emphasized → click “emphasize” in the pop-up toolbar.
62ED527B-2E05-4BCD-9AC7-06B263D3FB89
  • Effect: if “recall mode” is not turned on, the emphasized text will only display blue dotted line below; the emphasized box will deepen the background color
    6E01C887-44B8-4AC7-8187-72F547BEBD16
II. Continuous emphasize
In “Excerpt Settings :gear:” → “Emphasize mode” is turned on, you can make occlusion and fill in the blank for the excerpted notes
:warning:"Emphasize mode" and Recall mode" cannot be turned on at the same time
:warning:Only PDF can be emphasized continuously
1、Continuous emphasis of text
Select the notes that have been excerpted in the document interface → use the excerpt tool or text tool to excerpt or select the content to be emphasized
7C773835-804C-4604-96D6-25221977EBCC
  • Effect: The excerpted text will be grouped according to the words, forming a circle frame, waiting for the emphasized text; the blue dotted line will be displayed below the emphasized text
2、Continuous emphasis of excerpt by box
Select the note which is extracted by box from the document interface→ Use the rectangle tool to select the emphasized content by box
  • Effect: the emphasized box will deepen the background color
III. Emphasize in the outline
Studying module → open the notebook → open the mind map → click the list icon in the upper left corner
→ Click the “Edit” icon in the lower right corner of the list → click the “Emphasize mode” icon at the bottom of the list → open the “Emphasize” mode of the outline
180BCA7E-8FF6-4697-9C5F-AEE386957BFF
  • The excerpted text will be grouped according to the words, forming a rectangular frame, waiting for the emphasis;Blue dotted line is displayed below the emphasized text and the text fades;The emphasized box appears dotted box with light background color, and there are adjustable circles at four ends
IV. Emphasize in the comments
:warning:You can’t emphasize your own comments
In the note card comments, the excerpted non self input text is selected→ Click “Emphasize” on the left side of the input method toolbar to Emphasize the text
E134EACE-7E63-4FCE-90DF-0003153D4C38
  • Effect: emphasized text is bold and dotted blue line is displayed below
V. Emphasize in “Cloze” in the review module
Enter card→ Click the “Cloze” icon above→ Turn on emphasize mode in the list on the left
01687889-6DAB-4971-BD09-ACDD325DB2DE
  • Effect:The excerpted text will be grouped according to the words, forming a rectangular frame, waiting for the emphasis;Blue dotted line is displayed below the emphasized text and the text fades;The emphasized box appears dotted box with light background color, and there are adjustable circles at four ends
What’s the point of this feature? How is it different from marking some text with some color?
Well, try to emphasize something and then go to recall mode! Hopefully, that solves the mystery.
The emphasize mode serves two functions:
1. It can create occlusions while you are in recall mode.
2. It can create occlusions or cloze cards if you add the note to review mode.
MarginNote-Sushi
