Requests for PDF exports
It looks like MN3 has removed one of my favorite features (that was in MarginNote X) that was used to export PDFs. In MarginNote X, I set the following options for export:
-Export mindmap - OFF
-Export outline - ON
-Export highlighted pages only - OFF
-Export all pages - ON
-Export right margin - OFF
These settings created a PDF export that showed all of my MN-created annotations at the top of the document, with corresponding page numbers, and then the actually annotated text underneath in the body of the text. I hope MarginNote can revert back to the this PDF export format, since was such a crucial feature for me.
But…I would also suggest that MN include this feature and create the ability to click on the right margin for the PDF annotations outline (which signifies page number) so it takes users to the annotated text within the PDF document. In MarginNote X, that icon seems to click – but then doesn’t do anything.
Also, it would be great if this requested function – i.e., clicking on the annotations and/or the right margin for the PDF annotations outline – could work within any app (e.g., DEVONthinkPro) instead of having to open up the file within MarginNote. That just creates confusion, and jumbled mess if MarginNote opens (and imports) a file – just so one can see the reference to a particular annotation.
Thanks for considering this request! It would be a serious boon to MarginNote users…
Just wondering if this might something that MarginNote could implement in future editions. I’m already seriously missing the way I was able to export PDFs in MarginNote X – and was hoping that MN3 would build on it further!
Maybe other users have additional ideas / suggestions re: PDF exports…
BTW, it would also be great if this kind of export could work via Documents - as well as Notes. Thanks again for considering this request – really hope you consider it!
Hi jprint,
The number button works well in certain PDF APPS which support apple standard URL-Schemes. (eg:Notability,PDF-expert).Marginnote perfectly support URL-Schemes which is one of two IOS powerful features to enhance efficiency.
I think you’ve already found MN3 has the same export options with MN x now.
Best Regards,
MN Support Team
Hi @Lanco_Support-Team,
Thanks for informing me that MN3’s PDF export features now have the same options that existed in MNX. I’ve taken a closer look at them, and see that you’re right. So, thanks for that! Still, I continue to suggest the following…
Under MN’s export options, one can create an outline option. I’d suggest MN create the ability to click on the right margin for the PDF annotations outline (which signifies page number) so it takes users to the annotated text within the PDF document. In MarginNote X, that icon seems to click – but then doesn’t do anything.
Also, it would be great if this function – i.e., clicking on the annotations and/or the right margin for the PDF annotations outline – could work within any app (e.g., DEVONthinkPro) instead of having to open up the file within MarginNote. That just creates confusion, and jumbled mess if MarginNote opens (and imports) a file – just so one can see the reference to a particular annotation.
It also creates a cradle-to-grave problem: it forces users to wholly rely on MN when clicking on MN-created PDFs and therefore it means that all documents and links opened in MN can overwhelm its library. Make sense?
Thanks for considering all of this…
Hello everyone,
Thanks for adding this feature to MN3. I used the export with notes in the margin on a weekly basis to save my notes from lectures. It was great to have everything in one PDF that could be opened on any device.
It would be great to have this option back in MN4.
Ugh - didn’t realize this was lost in MN4 as I’m still figuring it out. I def used that feature a LOT so echo this request if it is now gone.
