Study Module
Study Module
:bookmark_tabs:Split view (only available under the learning module)
Split view
Resizing split view
Dragging a tab to enable split view
:memo:Mindmap Notebook
About Mindmap Notebook
Creating a Mindmap Notebook
Merging Mindmap Notebooks
Adding files to a Mindmap Notebook
PDF Editing
:mag:Search
Global search
Searching in current Mindmap Notebook
Filtering search results
:grey_question:Others
About jump key
Recovering files in a Mindmap Notebook
Swapping window sides
A post was split to a new topic: Study_Q1 How to open the multi-view function and increase the view?
A post was split to a new topic: Study_Q2 How do I resize a multi-view column?
A post was split to a new topic: Study_Q3 How do I drag a document tab into a split view or a separate window?
A post was split to a new topic: Notebook_Q1 What is a notebook?
A post was split to a new topic: Notebook_Q2 How to create a notebook?
A post was split to a new topic: Notebook_Q3 How do I merge notebooks?
A post was split to a new topic: Notebook_Q4 How to add (Associate) documents in a notebook?
A post was split to a new topic: Notebook_Q5 Edit PDF related issues
A post was split to a new topic: Search_Q1 How to perform “global search”?
A post was split to a new topic: Search_Q2 How to search only the current brain map and document content?
A post was split to a new topic: Search_Q3 How to filter the content after search?
A post was split to a new topic: Other_Q1 What is the jump key?
A post was split to a new topic: Other_Q2 How to replace associated documents without losing note data/How to recover lost / deleted documents in MarginNote 3?
A post was split to a new topic: Others_Q3 How to make the document on the left and the mind map on the right?
